Group: DynoMotion Message: 5541 From: mrosenfield2 Date: 8/15/2012
Subject: KFlop I/O ports
I want to use JP4/6 as inputs for reading axis select switches for my MPG. The manual indicates they are LVTTL, but does not indicate whether they have internal pullup resistors.
Do I need to add pullup resistors?
Michael Rosenfield
Group: DynoMotion Message: 5542 From: Tom Kerekes Date: 8/15/2012
Subject: Re: KFlop I/O ports
Hi Mike,
JP4 and JP6 are LVTTL and forcing any IO above 3.8V will cause damage to KFLOP.
The first 8 of 10 IO on both JP4 and JP6 have 150ohm pull down resistors (the remaining 2 IO are high impedance)
If your MPG can be wired to switch them to 3.3V that usually works best.
Group: DynoMotion Message: 5543 From: Michael Rosenfield Date: 8/15/2012
No problem - thanks!
Michael
